Kellefornia
« on: 15 March, 2018, 05:26:43 AM » |
After taking out my 66' Flavia Iniezione gas take to be welded (seems to be a trend on the forum lately) I noticed that it has two fuel lines exiting the tank but on my car only one of these lines is filtered, with an obviously non-stock filter.
I know that Iniezione cars have a filter at the engine bay. Can anyone confirm that this is the only fuel filter needed and that having one (or two) in line filters at the rear is incorrect? I'm thinking it wrong but want to be sure... may explain the hesitation issues my car has under full throttle prompting me to send out the KF for a service...
Also on the subject of fuel, can someone explain where the fuel overflow line is supposed to be routed? On my car (which I expect is also wrong) it goes all the way to a hole on the far right of the car. However, I noticed an unused hole leading to the outside in the spare tire well, which seems exactly where the line should be routed.
« Last Edit: 15 March, 2018, 06:00:53 AM by Kellefornia »
« Reply #1 on: 15 March, 2018, 06:53:32 AM » |
On my Flavia inezione I have a filter coming from the tank feed and this sits under a cover in the spare wheel recess before connecting to the metal supply pipe that runs to the engine bay to the fuel pump and the original fispa filter which is fitted after the pump. The filter at the back of the car is the only one. The other pipe you have identified is the fuel return (unfiltered). Cant help you with routing that line without photos.
KF setup is fussy on fuel pressure. If you have an original KF (Bosch) fuel pump it couldbe failing leading to fuel starvation at higher revs. My car was fitted with a standard 10bar pump, which I have subsequently regulated down to c2bar (cant remember the spec but it has to be quite precise).
Hope that helps.
Its not the winning but taking part! or is it taking apart? 1955 Aurelia B12 1967 Flavia Vignale iniezione 1967 Fulvia HFR 1972 1600 HF 1972 1600 Fulvia Sport 1978 Transformer HF3000 Strato's replica 1979 2500 Gamma Coupe 1988 Delta 1.6GTi.e.
Kellefornia
« Reply #2 on: 15 March, 2018, 10:20:02 AM » |
Understanding that the fuel filter is intended to be in the spare well and not simply underneath the car helps a lot and explains the purpose for the exit hole in the well (answering the second question).
The fuel overflow line comes from the top of the tank by the sender and goes across the car and out a hole beside the metal fuel filler pipe.
Any chance anyone has pictures of the fuel line routing from the tank to filter to supply pipe, as well as overflow line routing? The manual has some vague lines but nothing very instructive. Would be good to make mine correct and saves me crawling under the car to change the filter!
I'll look into how the fuel pump is working next.
Thanks all.
« Reply #3 on: 15 March, 2018, 10:30:30 AM » |
Car is tucked up right now so I cant take any photos but from memory your installation of the return pipe does not sound right. The supply and return run under the car to the tank area and are coupled flexibly close to each other near/through the spare wheel well. I use a 10cent disposable plastic filter. You should have a protective plate to cover it in the well.
Kellefornia
« Reply #4 on: 15 March, 2018, 10:48:48 AM » |
The fuel return line runs as you describe, back into the tank just beside the supply line, which on my car is not routed through the spare well (I do have the metal plate).
By fuel overflow line I mean the line originating out of the top side of the tank, by the Veglia sender, which runs to the outside and sprays your feet with gas should the tank be overfilled. The routing on mine looks quite hacked together and could do with some clean-up. Interested to know its original routing.
ColinMarr
Offline
« Reply #5 on: 15 March, 2018, 09:38:31 PM » |
What you describe as an overflow pipe is, I think, the tank breather. The pipe is designed to go up in the space between wheel arch and wing and then vent down to drain away anything in the pipe. On a Fulvia there should be a plastic expansion bottle in this line so as to drain back into the tank. It is likely that the Flavia had to same arrangement. It is not uncommon for this bottle to be omitted, which as you describe results in dollops of fuel onto the shoes. I suggest you learn to live with petrol smelly shoes, or fit a plastic bottle in the upside of the line.
Colin
« Reply #6 on: 15 March, 2018, 10:08:14 PM » |
This is as Colin says a vent pipe and on my Flavia is a continuous pipe that goes up the wheel arch and back down a small port in the inner wing to the front of the wheel arch (I think from memory) - a bit of a lash up compared to the later Fulvia.
Kellefornia
« Reply #7 on: 15 March, 2018, 11:30:36 PM » |
Thanks all for the excellent description. Glad I joined the LMC!
