Hi all
As part of my rehab I decided to give a Consortium member in Norway a helping hand as he had no heater motor in his S3 brrrr...
I found a motor still in the housing and managed to persuade it out into the daylight after 50+ years. The fastenings that look like rivets are in fact pins that go through the housing into a rubber sleeve that sits between the motor and the housing. The motor was quite stiff so I left it to soak overnight with some lubricant and then connected it up to a 12v supply. It much to my surprise burst into life but seemed to run a bit slowly and erratically.
So I decided to have a look inside...
The pins used for fixing sound the same as used on Flaminia & Fulvia , and no doubt other models as well, like yourself i thought they were rivets, but it makes it so easy to remove the motor.
8227
