Model Technical and Interest => Lambda => Topic started by: davidwheeler on 17 November, 2015, 02:19:03 PM
Title: Front propshaft.
Post by: davidwheeler on 17 November, 2015, 02:19:03 PM
I long ago replaced the rear propshaft of Old Boot with a modern tubular one fitted with Hardy Spicers, with good results.   I now am considering the front joint between the front propshaft and the gearbox.  Sheila, who came from Oz, has had the fibre disc replaced by a Hardy Spicer fitted, so far as I can see, direct to the taper on the front  of the original solid shaft.    Theoretically this is not a good idea as there is no significant movement in the joint to spread the load around the needles but it seems fine still after a good few thousand miles.    Has anybody else any experience?  I am thinking of getting a Ben-type aluminium disc with Silentblocs fitted in to it (see Aprilia thread) made up as a better solution.
Title: Re: Front propshaft.
Post by: Tony Stephens on 18 November, 2015, 06:45:04 AM
Only problem Is that this is quite visible when you look under the bonnet. The Lambda Consortium has stock of the Hardy-type fibre disc as original although they are pricey.
However I am aware you know this, and I am preaching to the (un)converted!
Post by: davidwheeler on 18 November, 2015, 05:29:07 PM
I'll paint it black!
Post by: Tony Stephens on 29 November, 2015, 08:37:50 AM
By the way, when I got a new rear propshaft made (out of an Austin Gypsy front shaft obtained from Aylesbury's scrap yard) some years ago, I had this done by Recoprop in Luton, whom I recommend. They also took the solid front shaft in to check the balance - with some misgivings because of its apparent age, and only because I assured them I had checked it in the lathe and there was minimal runout.
On returning the whole lot to me: new rear shaft, centre bearing and front shaft:they showed me the tiny balance weight they had had to add, and said they were astonished at the quality of this original '20's part.
Post by: fay66 on 29 November, 2015, 12:20:23 PM
I'd recommend Recoprop as well, having rebuilt the one off my Suzuki Cappuccino for me.
8227 8)
