Title: Tyre Pressure for Michelin XAS Post by: nthomas1 on 13 August, 2015, 09:59:59 PM From experience, what is the optimum tyre pressure for Michelin XAS tyres on standard S2 Coupe steel rims - for normal driving with one or two on board? Thanks in anticipation, Norm
Title: Re: Tyre Pressure for Michelin XAS Post by: lancialulu on 14 August, 2015, 07:06:25 AM Around 24psi all round. Are they new rubber?
Title: Re: Tyre Pressure for Michelin XAS Post by: nthomas1 on 14 August, 2015, 07:24:35 PM Thanks for the response. Based on appearance I'm guessing they were fitted in the last 12 to 18 months.
Title: Re: Tyre Pressure for Michelin XAS Post by: lancialulu on 14 August, 2015, 07:28:46 PM If they squeal round the round abouts they may be a bit older ;)
Title: Re: Tyre Pressure for Michelin XAS Post by: rogerelias on 14 August, 2015, 08:01:34 PM look on the sidewall and you may see numbers like 2314 or similar in small numbers, which means tyres were made the 23rd week of 2014,
Title: Re: Tyre Pressure for Michelin XAS Post by: davidwheeler on 15 August, 2015, 08:35:06 AM According to the handbook, 1.5Kg/sq.cm = 21.3psi to 1.7Kg/sq.cm = 24.1 psi for long runs fully loaded at high speed front and rear.
Title: Re: Tyre Pressure for Michelin XAS Post by: nistri on 24 August, 2015, 06:23:48 AM If the tyres were made recently, they may need a much higher pressure (usually 2 bar).
Andrea Title: Re: Tyre Pressure for Michelin XAS Post by: the.cern on 24 August, 2015, 09:17:20 AM I had noticed that, in general, required tyre pressures tend to higher now compared with say 30 or 40 years ago. Way back then, 24psi would be fairly standard, whereas now, as Andrea has suggested, 2bar (29psi), if not higher, say 2.3bar (34psi) seems routine.
Is anyone able to shed some light on this shift please? Andy Title: Re: Tyre Pressure for Michelin XAS Post by: John B on 24 August, 2015, 09:46:01 AM Would it be anything to do with the change from cross ply to radial ply tyres?
Title: Re: Tyre Pressure for Michelin XAS Post by: lancialulu on 24 August, 2015, 11:01:49 AM Most likely due to side walls being lower profile on more modern tyres. So if running non standard lower profile tyres like I do I tend to go to 2bar.
Cant remember when Lancia stopped fitting crossplies but it must be pre Aprilia. Title: Re: Tyre Pressure for Michelin XAS Post by: Neil on 24 August, 2015, 11:47:45 AM Tim, I think you are right, Fulvia always had radial tyres, but they would have been 82 series, today only 80 series tyres are generally available, which are marginally lower profile: 2Bar (~28psi) works well in my experience.
Title: Re: Tyre Pressure for Michelin XAS Post by: JohnMillham on 24 August, 2015, 01:40:49 PM Most likely due to side walls being lower profile on more modern tyres. So if running non standard lower profile tyres like I do I tend to go to 2bar. The first Michelin Xs were fitted to Aurelias, so well after the Aprilia. See Longstone Tyres website, where there's a bit of tyre history. Cant remember when Lancia stopped fitting crossplies but it must be pre Aprilia. Regards, John Title: Re: Tyre Pressure for Michelin XAS Post by: fay66 on 24 August, 2015, 05:37:47 PM Tim, I think you are right, Fulvia always had radial tyres, but they would have been 82 series, today only 80 series tyres are generally available, which are marginally lower profile: 2Bar (~28psi) works well in my experience. When I bought "Fay" she had what I believe was the original 155,14,x80 Michelin X's fitted, as she'd only done 27,000 miles with the original owner, and it looked like the spare had only been used lightly. Brian 8227 8) Title: Re: Tyre Pressure for Michelin XAS Post by: davidwheeler on 25 August, 2015, 07:00:13 PM Agree, Aprilias were originally cross ply but Michelin X suited them very well. Now universally on radials I suspect. Agree also, 22 psi on my Fulvia means impossibly heavy steering with modern tyres. Currently at 28 psi but tempted to go higher...
Title: Re: Tyre Pressure for Michelin XAS Post by: fay66 on 25 August, 2015, 10:40:36 PM David,
The new Dunlop Street Response i've just fitted to my 2c are very good once the wheels are moving, even very slowly, so I have no complaints I run 28psi all round. Brian 8227 8) Title: Re: Tyre Pressure for Michelin XAS Post by: davidwheeler on 28 August, 2015, 08:38:16 AM Lancialulu may be on to something re. sidewalls. I have Michelin X (new and very expensive) on the Aprilia. Running at 24 psi the steering is still as light as a feather (but then I don't think any Fulvia can approach sliding pillar steering). XAS insofar as I am aware are the same as X apart from the asymmetrical tread so maybe you should go with the handbook pressure at least at first.
Title: Re: Tyre Pressure for Michelin XAS Post by: simonandjuliet on 28 August, 2015, 09:09:50 AM I run my "X"s at 24 psi
Title: Re: Tyre Pressure for Michelin XAS Post by: davidwheeler on 30 August, 2015, 05:33:42 PM Having just ried 22 so shall I - on the Aprilia. Not a hge difference but noticable. Incidentally, just had great fun round a motorway roundabout at 45 mph.
Title: Re: Tyre Pressure for Michelin XAS Post by: RobD on 04 September, 2015, 09:12:14 PM I wouldn't disagree with any of the advice being offered, a good sense check is to have a quick feel of the tyres after a motorway run. If they feel very hot add a few psi and vice versa if they're not getting up to temperature. Not very scientific and rather subjective but it will definitely get you in the ball park.
Title: Re: Tyre Pressure for Michelin XAS Post by: the.cern on 04 September, 2015, 09:22:51 PM I wouldn't disagree with any of the advice being offered, a good sense check is to have a quick feel of the tyres after a motorway run. If they feel very hot add a few psi and vice versa if they're not getting up to temperature. Not very scientific and rather subjective but it will definitely get you in the ball park. Wonderful bit of common sense there Rob !! Andy |
