Buy, Sell and Search => Spares for sale => Topic started by: lancialulu on 28 January, 2015, 10:59:42 AM
Title: 1.3 Beta or maybe Delta Engine / Airbox / Gearbox
Post by: lancialulu on 28 January, 2015, 10:59:42 AM
In Glasgow.
Let me know if interested and I will forward email.
I am advised a best price secures.
Title: Re: 1.3 Beta or maybe Delta Engine / Airbox / Gearbox
Post by: peteracs on 28 January, 2015, 03:29:35 PM
Curious what it is off, it is early type with exhaust ports at the back, but not off any Beta AFAIK (unless early Saloon)?
Post by: simonandjuliet on 28 January, 2015, 03:53:02 PM
"AFAIK" - "as far as I know" ????? Not come across that before
Post by: lancialulu on 28 January, 2015, 03:54:42 PM
The part number on the exhaust manifold cross references with Beta 1.3.....AFAGK (as far as Google Knows!)
Post by: SanRemo78 on 28 January, 2015, 06:43:49 PM
Was the Beta 1.3 available with a cam mounted distributor? Thought they were all block mounted at the front with only the i.e. and VX having the dizzy there?
Post by: lancialulu on 28 January, 2015, 06:52:29 PM
Thats why I think it could be a Delta 1.3 but the exhaust number is confusing.
Post by: Sebastien on 28 January, 2015, 07:06:19 PM
Delta 1.3 and Delta 1.5 were SOHC, not DOHC.
DOHC came with the Delta 1.6 GT.
Best use for that lump of (corroded) aluminium would be as a doorstopper  (IMHO);D
Post by: SanRemo78 on 28 January, 2015, 09:30:13 PM
It's not Beta, not with those engine mounts. None the wiser though! Carb ducting ought to give someone a clue?
Post by: lancialulu on 28 January, 2015, 10:37:18 PM
Very Delta like then? An early 1.6??
Post by: peteracs on 28 January, 2015, 11:23:16 PM
Hi Simon
Oops, sorry about that.... Must use full words
Post by: peteracs on 28 January, 2015, 11:28:33 PM
What made me think it was maybe early Beta was what looks like a metal cover for the timing belt, the later Betas all had yellow plastic ones I think, but the engine mounts are definitely not Beta as mentioned, hence wondering if it was an early saloon, but I thought all of them had a similar mounting scheme.
So maybe the engine was transplanted into something else?
The answer is to get the number near the oil filter which would settle it.
Post by: fay66 on 29 January, 2015, 09:26:22 PM
Can't say I've ever seen that cambelt cover on a Delta?
8227 8)
Post by: lancialulu on 29 January, 2015, 09:51:08 PM
Its seems not to be "Work In Progress" the way all the pipes have been cut. The cam covers do not have Delta recessed fastners. Could it be a Monte???
Post by: peteracs on 29 January, 2015, 10:23:55 PM
Not convinced the mount or the air filter is Monte. I guess we need the engine number...
Post by: lancialulu on 30 January, 2015, 07:05:09 AM
The seller is not able to get more info. Based in Glasgow so if anyone wants to go look......
Post by: SanRemo78 on 30 January, 2015, 08:56:56 AM
Not a Monte motor Peter, the dizzy is in the wrong place for that, Monte Carlos are on the exhaust cam bank... It's a mystery alright!
Post by: neil-yaj396 on 30 January, 2015, 05:53:50 PM
The oil filler is at the wrong end for a Beta. The dizzy and engine mounts are also non-Beta as mentioned. Prisma or Dedra?
Post by: lancialulu on 30 January, 2015, 11:13:18 PM
Early 1.6 Delta. (Or Prisma)
