Model Technical and Interest => Fulvia => Topic started by: andyford on 28 September, 2014, 02:25:08 PM
Title: Front hub removal tool
Post by: andyford on 28 September, 2014, 02:25:08 PM
I looking to remove the front hubs from my series two HF, does anyone local to Bristol have the correct 3 prong tool that I can borrow.
Failing that is there a drawing of the tool required so I can make one.
Title: Re: Front hub removal tool
Post by: fay66 on 28 September, 2014, 05:09:45 PM
Tools are available through the club tool hire, if you look in the back of 'Viva Lancia' you will find the contact details for Tim Heath
(Lancialulu), you'll need the puller as well.
8227 8)
Post by: Richard Fridd on 28 September, 2014, 06:40:51 PM
And something to clamp the tool on, to prevent it slipping
Post by: andyford on 28 September, 2014, 07:59:27 PM
Thanks for the replies.
Emailed Tim this evening, just hope he hasn't hired it out as I'm ready to remove these parts.
Failing that it's back to the bodywork😩
Post by: lancialulu on 29 September, 2014, 07:21:03 AM
I have emailed Andy and tools are currently available.
Post by: andyford on 30 September, 2014, 07:12:06 AM
Wow, that was easier than I thought, cheque went off last night.
Not sure what the problem is but felt a bit of vibration under braking.
Might as well sort all niggles whilst the subframe is out.
In hindsight I should have loosened the hubs prior to removing the subframe but we live and learn, will get 4 mates to stand on each corner to keep it down!
Thanks again for all your help.
Post by: Richard Fridd on 30 September, 2014, 08:03:40 AM
"We all Live and learn" Trial and Error, Experience.. I have learnt that before returning tools, it might be wise to retorque the hubnuts, to ensure they really are still nice and tight.
Post by: nistri on 01 October, 2014, 11:20:19 AM
One (out of many) possible cause for vibration under braking is slack allen keys fixing the inner CV joint(s) to the gearbox. Worth checking this out, Andrea
Post by: lancialulu on 01 October, 2014, 11:24:34 AM
Also if the front disks are worn down or warped or pads causing local corrosion when stood for a few years best to put new disks on. If skimmed make sure you do not go below min thickness.
Post by: andyford on 01 October, 2014, 07:50:23 PM
Stripping parts down in anticipation of the arrival of the tools from Tim and decided to look at the nuts, one looks fine but the nearside one looks as if a quality bodger has been having a go at trying to loosen it. May prove a challenge getting this one off. Might not chance LMC tools on this part!
Post by: the.cern on 01 October, 2014, 09:07:47 PM
Oh dearie me, someone got frustrated didn't they!!!
I do hope that it is not so damaged that you are not able to remove the nut. Are new nuts available? It would seem that is what you need.
Good luck,
             Andy
Post by: davidwheeler on 06 October, 2014, 09:40:03 AM
New nuts from Omicron, should be fitted in any case.  You may weld something onto the old nut to get it off and then Throw It Away!!
