Model Technical and Interest => Flaminia => Topic started by: Charles Frodsham on 06 November, 2013, 08:13:31 PM
Title: Flaminia Rear Brakes
Post by: Charles Frodsham on 06 November, 2013, 08:13:31 PM
I am thinking of starting a winter project, and am after some advice if anyone can help please?
I am looking to remove rear calipers on my PF, to upgrade with Aluminium cylinders (BG Developments). I have done the front brakes with success - see attached.
Is it really practical to attempt this, including renewing brake pipes in situ? Top bolts for the calipers look tricky, not much space for the lower one even. Do the half shafts/couplings need to be removed. Is it easier to drop gearbox anyway, and possibly replace discs at the same time (are rear disc available anyway????)
Any advice welcome....polite please!  ;D
Title: Re: Flaminia Rear Brakes
Post by: DavidLaver on 06 November, 2013, 11:19:05 PM
What are the reasons NOT to drop the gearbox?  The brakes will need bleeding anyway.
David
Post by: Richard Fridd on 07 November, 2013, 07:15:44 AM
Nice looking brake assembly. I have removed/refitted the pistons, pads and pipes in situ, callipers probably require at least partial dropping of the transaxle.If the discs are available I would remove the transaxle and do every thing at once. I have had a spare pair skimmed, (yet to be fitted) as there was plenty of material remaining
Post by: dannels on 07 November, 2013, 12:41:34 PM
It is possible to replace them in situ (I've done it on mine) - getting access to the top bolts from the boot access panel
However if you plan to replace the discs you may as well drop the whole trans
Post by: Charles Frodsham on 07 November, 2013, 07:30:14 PM
Thanks very much for your replies.
I will remove transaxle and do the calipers and disc all in one hit, as you suggest. (also the clutch whilst I am at it)
Any suggestions on how to lift/lower gearbox? It looks formidably heavy! I have car on 4 post lift.
Post by: Charles Frodsham on 09 November, 2013, 08:50:18 PM
Anybody know how heavy flaminia transaxle is?
Post by: Richard Fridd on 09 November, 2013, 09:28:34 PM
60 Kilos?
Post by: Charles Frodsham on 10 November, 2013, 05:57:50 PM
Thanks Richard.
I was thinking of using a scissor lift to lower assembly, which is rated at 300kgs.....I would have thought the transaxle is less, but wanted to cross check, as the consequences would be dire. Sounds like I would be safe with this.
Post by: Charles Frodsham on 22 November, 2013, 10:25:17 PM
It is done ....and I still have all my limbs! :D
Post by: the.cern on 22 November, 2013, 10:46:57 PM
Well done Charles, next task, clean everything!!!
It will be so much easier to check everything and do the necessary work with the unit sitting there bereft of car !!!!!
                                  Andy
Post by: Charles Frodsham on 26 November, 2013, 08:36:08 PM
Any ideas what this sensor is for on gearbox selector? Reverse light?
Post by: simonandjuliet on 26 November, 2013, 08:43:52 PM
I am sure you are correct about the switch, I cannot comment, but would just like to say how nice your car looks from underneath ! All clean, neat and tidy ....
Good luck
Post by: Charles Frodsham on 26 November, 2013, 08:57:04 PM
Thanks very much  ;D
Post by: DavidLaver on 26 November, 2013, 11:35:32 PM
I do like seeing all the hidden bits.  Well done!!   Easier than feared or a job that went on and on?
David
Post by: Charles Frodsham on 27 November, 2013, 10:37:11 PM
It was all relatively straight forward. The axle shackles required some persuasion. It's just finding the time and having the confidence to start!
Post by: Charles Frodsham on 30 November, 2013, 09:18:03 PM
Brakes and discs removed. Caliper bolts are difficult to access, so I removed handbrake assemblies and pipe work first. Caliper pistons were very stiff in cylinders. I dont know how I would have disassembled without transaxle removed from the car.
Post by: Charles Frodsham on 30 November, 2013, 09:41:38 PM
Reference the reverse selector switch ( for reversing light) mentioned earlier in thread, I am pretty sure that this is what it is, but I cannot see it listed in the Parts manual. My car seems to have a lashed up system (see photo) probably because the sensor failed at some point in its history. I have removed the sensor and it has a small probe which appears to have lost it 'spring', so no longer protrudes as necessary. Any body have a clue if the sensor is available or repairable?
Post by: Charles Frodsham on 05 December, 2013, 05:34:15 PM
Clean gearbox!  ;D
Post by: the.cern on 05 December, 2013, 10:02:52 PM
That looks really good Charles. Now you can begin to play without getting yourself and, more importantly, components covered in gritty dried up grease.
Good luck with whatever stripping and dismantling is required.
                                                 Andy
Post by: DavidLaver on 06 December, 2013, 12:17:32 AM
Good progress.
What did you use to clean it?
David
Post by: Charles Frodsham on 06 December, 2013, 09:22:37 PM
Thanks guys.
I used the 'green' version of GUNK, which seemed to work ok, with a bit of scrubbing.
The calipers have been sent off to BG Developments for plating (claw) and new cylinders and pistons as shown earlier in thread (anodised aluminium and stainless pistons). They supply Viva-Lancia if you have seen them on their website.
I am hoping they can manufacture new discs for me, but will keep you posted!
Omicron have supplied new gearbox mounts and a reverse light switch.
Happy days!
Post by: Dave Gee on 07 December, 2013, 01:30:23 PM
Charles
If you are struggling for discs, let me know - I have some spares that will skim.
Dave
Post by: Charles Frodsham on 07 December, 2013, 04:34:02 PM
Thanks for the offer Dave.
The old ones are pretty good with plenty of thickness ( 12.5 mm). They are a little pitted in places but will clean up.
If I can get new ones, in theory I will not have to remove gearbox again for a long time, or ever!
Post by: Charles Frodsham on 24 December, 2013, 01:24:12 PM
Look what Santa brought!
Happy Christmas.
Post by: Charles Frodsham on 10 January, 2014, 09:15:11 PM
Just a quick update.
Omicron kindly suggested stripping/cleaning/reassembling/greasing rear axle 'pots' would be a good idea, whilst off the car. These items are not serviced very often, and apparently can be a cause of flaminia gearbox failures.
One done with new 'boot', and one to go.
Post by: Charles Frodsham on 31 January, 2014, 10:14:44 PM
Rear brakes all rebuilt and ready to go.
Post by: Parisien on 31 January, 2014, 10:21:38 PM
Looking very smart, job well done
P
Post by: simonandjuliet on 01 February, 2014, 08:20:19 AM
Should stop well ! - looks great ...
Post by: DavidLaver on 01 February, 2014, 08:56:29 AM
How did you clean the calliper "saddles" - looks fabulous.
David
Post by: dannels on 01 February, 2014, 11:58:11 AM
Great work Charles
One question - the gearbox 'filler cap' - that sits ontop of the transaxle - mine will not undo - I assume it's threaded - or does it just pull out?
The T is soft so I can't just hit it or it will bend and heat hasn't proved very fruitful - it's just softening the metal! Any ideas?
Dave
Post by: the.cern on 01 February, 2014, 06:02:45 PM
Charles, that looks marvellous and I am sure there will be a commensurate improvement in the braking power. With rebuilt pot joints you have a done a great job.
                      Andy
Post by: Charles Frodsham on 01 February, 2014, 08:25:14 PM
Thanks for all the comments guys. Lets hope it all works!  ;D
Dave, the 'filler cap,' or dipstick, is on a fine thread, so it should just unscrew.
David, the caliper 'claws' are plated. The aluminium brake cylinders and plating were done by those helpful chaps at BG Developments (as were the discs).
Post by: DavidLaver on 01 February, 2014, 11:13:38 PM
http://www.bgdevelopments.co.uk/index.php?option=com_content&view=article&id=71&Itemid=85
Post by: dannels on 02 February, 2014, 11:35:57 AM
Thanks Charles - I was afraid of that - my dipstick/filler does not want to play!
I also have BG Developments piston assemblies all round - i'd also recommend!
Dave
Post by: Charles Frodsham on 02 February, 2014, 11:56:15 AM
Hi Dave
Just a thought...have you tried a 'freeze' release agent on the dipstick/filler itself, so that it shrinks a little. Sorry if this is stating the obvious, but it worked for me on a difficult spark plug once!
Regards Charles
Post by: dannels on 09 February, 2014, 06:43:01 PM
Never used that stuff before - but it did the trick - many thanks!
Dave
Post by: Charles Frodsham on 14 February, 2014, 05:18:01 PM
Car is now running and brakes work splendidly! Even the MOT man was impressed.  ;D
Bleeding the brakes was very difficult, until I made a 'custom' spanner.
