Title: 8 Valve Integrale Engine Data Post by: ben on 19 January, 2012, 08:27:03 PM Can anybody help me please.
I have my 8valve Integrale engine in bits to fit new belts etc and a new set of exhaust valves. Can someone give me the torque settings for the head bolts and the cam-box bolts. Also what should the tappet clearances be--(and where is the best place to get shims if I need them?) Thanks Ben Title: Re: 8 Valve Integrale Engine Data Post by: fay66 on 19 January, 2012, 10:34:17 PM Can anybody help me please. Ben,I have my 8valve Integrale engine in bits to fit new belts etc and a new set of exhaust valves. Can someone give me the torque settings for the head bolts and the cam-box bolts. Also what should the tappet clearances be--(and where is the best place to get shims if I need them?) Thanks Ben Manual says Head Bolts M10 x1.25 tighten to 2 DaNM Final Setting 4 DaNM + 90 Degrees in stages.UPDATE Ben has just pointed out that I made an error and it should then be a further 90 Degrees. Top Cylinder Head Bolt M8 ? 2.2 DaNM. Cam Cover Bolts the manual states torque to specification but doesn't then say anywhere what that is ::) Tappet Clearance see below. Brian 8227 8) Title: Re: 8 Valve Integrale Engine Data Post by: ben on 20 January, 2012, 12:41:33 PM Many thanks Brian---------first to the buzzer as usual!
Ben |
