Model Technical and Interest => Fulvia => Topic started by: kernow on 16 September, 2011, 06:38:14 PM
Title: Fulvia Sport on the road again... kind of.
Post by: kernow on 16 September, 2011, 06:38:14 PM
Hi All,
Finally got the FSZ on the road. Bought the car in April from original owner, 20 years off the road. Lots of recommissioning - all the usual things. Here's the first run out, followed by first breakdown :D debris in fuel tank working free. Tank now away for cleaning and relining.
Hopefully back on the Cornish roads again soon,
Title: Re: Fulvia Sport on the road again... kind of.
Post by: rogerelias on 16 September, 2011, 06:52:09 PM
Well done, :) enjoy my restoration/bodywork battle has just begun, welding starting Sunday ???
Post by: ian on 16 September, 2011, 06:53:41 PM
nice   ;D
Post by: ColinMarr on 16 September, 2011, 08:30:27 PM
Chris, Your car looks great! I hope you enjoy it as much as I have mine.
Colin
Post by: chriswgawne on 17 September, 2011, 06:35:32 AM
Great to hear of another one on the road. Well done They really are lovely to drive.
chris
Post by: lancialulu on 17 September, 2011, 06:37:40 AM
Brilliant - another FSZ hits the road! You dont appear to be in the Z register maintained by Roddy Young. He would be very happy to add your car I am sure.
When I restored my FSZ some 5 years ago, I only had a couple of breakdowns (one in a forest in the Ardennes), but am still "debugging" minor issues. However it is a consumate pocket GT car for continental work. Melloni (which is what our family call her) has just returned from a 1000 mile weekend in Burgundy which I have written up for a future issue of VL.
Post by: Dilambdaman on 17 September, 2011, 09:03:52 AM
Well done Chris, look forward to seeing it sometime.
Robin.
Post by: kernow on 17 September, 2011, 11:48:07 AM
Thanks guys - looking forward to putting some miles on the car. Shame I missed the summer but lots of niggly little things to fix. Looking forward to an Indian Summer (fingers crossed).
Post by: kernow on 21 September, 2011, 07:15:07 PM
OK, I think the fuel tank is pretty shot :-\. Any ideas where I might track down a good second hand replacement?
Post by: DavidLaver on 21 September, 2011, 10:15:16 PM
Its not that expensive having a tank made.  Someone on here will know the contact of Graem (GB Fabrications or something, Google's not helping and I don't have my book to hand) who's a wizz with ali and who's son had a Fulvia Zagato off Richard Fridd a while back.  Worth a call at least.  You'd then know it was clean, baffled, and perhaps even some foam in there for peace of mind.
David
Post by: Richard Fridd on 22 September, 2011, 06:27:00 AM
Graham Bates is at GB ENGINEERING, LOWBARN WORKSHOP, POND VIEW, STAPELEY MANOR ,LONG LANE, ODIHAM, HAMPSHIRE, RG291JE tel 01256862001.Graham also has those suspension bushes which fit fulvia front suspension arms.Brise Fabrications at Dartford Kent also are good for bespoke fuel tanks etc.best regards richard
Post by: lancialulu on 22 September, 2011, 06:47:42 AM
I bought a new one from Cavalitto (over email) some 6 years ago. Came with a Lancia part number tag...
Post by: kernow on 27 September, 2011, 11:17:10 AM
Thanks for the suggestions - Might have found a tank. Thinking of upgrading to an electronic fuel pump at the same time to eliminate a potential source of problems. Any tips?
Post by: thecolonel on 27 September, 2011, 05:08:23 PM
Yep,
http://www.fuelpumpsonline.co.uk/
Geoff
Post by: fay66 on 27 September, 2011, 10:45:52 PM
 Hi Chris,
Many of us have kept the mechanical fuel pumps that on the whole perform quite well, but have added a fuel filter/regulator if one isn't already fitted, (I used a filter king from Demon tweeks) and have also fitted a solid state or otherwise electric pump, to eliminate all the churning over that seems to be part and parcel of most, if not all fulvia starting after standing a few days.
In my case I've had one fitted adjacent to the fuel tank on my 2c with a switch and warning light, this is turned on until it stops clicking and the warning light stops flickering, then with a bit of choke she fires first time, it's also nice to know you have a backup if the mechanical pump fails, but this hasn't happened in 12 years and 20,000 miles.
8227 8)
Post by: lancialulu on 28 September, 2011, 12:28:11 PM
I have the pump on the right inside wing which works well. Other bits are like Brian's installation.
Post by: kernow on 17 March, 2012, 02:46:33 PM
So, finally managed to track down a fuel tank for the Sport. It's a Series 1 tank so took it to a local tank/radiator refurbisher and they fitted the return pipe that's missing from the S1 tanks (as my car is an S2). Got the tank back yesterday and awoke with a real spring in my step at the thought of the car being back on the road. Just before refitting it, some weird instinct made me peer down the fuel feed pipe and bingo - day light! Further investigation with a torch revealed a large hole in the pipe inside the tank near where it meets the tank wall.  >:( One concillation is that I checked before fitting otherwise it would just have been sucking air and not fuel to the carbs!
Is this a common fault? Ahhh! Back to the tank repair garage.
Post by: lancialulu on 17 March, 2012, 06:04:50 PM
Never heard of this. The pick up pipe should go to the bottom directly in line with the drain plug which has a complex muck filter assembly on the drain plug itself.
Post by: kernow on 17 March, 2012, 07:30:55 PM
The hole is where the pick-up pipe exits the tank, about 5mil from the tank wall. Can't believe I actually checked. Spot of luck, could have spent ages trying to diagnose the problem...
Post by: kernow on 31 March, 2012, 08:21:34 AM
Tank fitted :) still fuelling problems :( Replacement standard pump didn't solve it. Next step, electric fuel pump set-up. Graham Eddy is trying to sort it, but having broken down three times taking the car around the block, when I dropped in the other day the car was sitting in the corner of his workshop awaiting the arrival of said pump. I just realised it's been almost a year since I bought the car. Who said recommissioning was an a simple job?
More news soon hopefully.
Post by: fay66 on 31 March, 2012, 10:24:41 AM
"Who said recommissioning was an a simple job?"
No one in their right mind ::)
Once you've got it sorted and on the road, all the problems fade into insignificance!
8227 8)
