Title: Beta parts Post by: Watshot on 03 December, 2006, 06:16:53 PM UPDATED 29-02-08 :) New items are indicated with a :)
Last of my Beta parts, mainly Coupe with 44k miles, many will fit all. Contact Paul through forum or directly on 01295 730610 Cheers. PANELS FRONT LOWER PANEL A1 £30.00 BOOTLID A1 £30.00 GLASS REARSCREEN Working elements £30.00 O/S Q/LIGHT With holes £10.00 REAR O/S Q/LIGHT Complete in chrome frame £15.00 REAR N/S Q/LIGHT Complete in chrome frame £15.00 O/S DOOR £15.00 N/S DOOR £15.00 EXTERIOR TRIM VX FRONT AIR DAM Near perfect condition £50.00 FRONT BUMPER (EARLY) Excellent straight example £30.00 PAIR CHROME GUTTERS (COUPE) £7.50 each COMPLETE S3 SIDE RUBBING STRIP SET Rear section for coupe or HPE £40.00 BOTH LONG CURVED DOOR WINDOW CHROME PIECES £5 each COMPLETE N/S COUPE REAR LIGHT UNIT £20.00 AS ABOVE O/S WITH BROKEN CHROME FRAME £5.00 S3 FRONT BADGE (LANCIA SHIELD) £5.00 S3 BOOTLID BADGE (LANCIA SHIELD) £5.00 INTERIOR TRIM REAR SIDE PANELS (Blue twill) £5 each PAIR OF S3 DOOR PULL HANDLES £5 each COMPLETE CLOCKS/GAUGES SET Complete working order Shows 44k miles £25.00 CHROME FIXING STRIPS TO BOTTOM EDGE OF DOOR CARDS £5 each ORIGINAL RED 'DOOR OPEN' LIGHTS (Replaces reflectors on doors) NEW :) All variants-Nice upgrade £20.00 ROCKER SWITCHES S2/S3 ALL TYPES £0.50-1.00 CIG LIGHTERS S2/S3 FAN SWITCHES £1.00 ENGINE ANCILLARIES FAN ASSEMBLY £10.00 ELECTRONIC IGNITION UNIT £10.00 ALTERNATOR 55 AMP £20.00 DISTRIBUTOR £10.00 WEBER CARB 34DAT 1/250 Sticking choke (1600 jets) £10.00 COIL £10.00 OTHER MECHANICAL PARTS ETC FUSE BOX £20.00 MANUAL STEERING RACK Only 44k miles £20.00 WIPER MOTOR WITH COVER £20.00 WIPER MOTOR £5.00 N/S REAR HUB WITH BACKPLATE INTACT Only 44k miles £10.00 O/S REAR HUB (No backplate) Only 44k miles £5.00 ORIGINAL HORN WITH COMPRESSOR £5.00 BRAKE BIAS VALVE £5.00 PAIR OF ELECTRIC WINDOW REGULATORS £20 each BENDIX COMPLETE CAR SET OF BRAKE PADS NEW :) £20.00 MINTEX FRONT AXLE SET OF BRAKE PADS (With sensors) NEW :) £12.00 CABLES NEW SPEEDO/THROTTLE/CLUTCH NEW :) £7.50 each SPEEDO/OUTER CLUTCH £5 each OTHER S2 FL HANDBOOK ALL VARIANTS (Approx '79---'81) Good example with ribbon £10.00 SET OF FRONT AND REAR FOG LIGHTS (Aftermarket by 'Ring') Very little use With front grilles and bulbs £10.00 Title: Beta parts Post by: Watshot on 24 February, 2007, 08:33:17 PM :-*
Title: Re: Beta parts Post by: Watshot on 01 May, 2007, 10:24:50 PM :P
Title: Re: Beta parts Post by: Watshot on 23 September, 2007, 06:31:42 PM Updated. All parts listed above still available. Thanks.
Title: Re: Beta parts Post by: Watshot on 29 February, 2008, 09:54:49 AM Bump.
Title: Re: Beta parts Post by: neil-yaj396 on 23 July, 2008, 08:36:52 AM Paul
Have you still got a Beta clutch cable? I am going on holiday in the Beta next month and am desperate to find one!! Neil |
