Title: That nearly worked Post by: Harvey on 28 May, 2009, 12:44:22 AM In full gung-ho mode, I attempted to upgrade the forum software. It seems to have mostly worked, but the boards are in a different sequence. Please let me know if you spot anything else awry.
Title: Re: That nearly worked Post by: Harvey on 28 May, 2009, 09:40:52 AM "Mostly" = not really. As soon as I switched off last night, in came the error messages. :(
Title: Re: That nearly worked Post by: sparehead3 on 28 May, 2009, 09:42:49 AM Should be ok now - upgrading software at 1:44am is not a good idea :)
Title: Re: That nearly worked Post by: Harvey on 28 May, 2009, 09:49:35 AM It seemed such a good idea when I started, but it took a lot longer than expected, being such a novice.
Title: Re: That nearly worked Post by: fay66 on 28 May, 2009, 07:07:31 PM Thanks Harvey,
Brian 8227 8) Title: Re: That nearly worked Post by: Harvey on 15 July, 2009, 04:20:24 PM Brace yourselves. There's an update available and I'm going to have a go at it in the next couple of days. If the forum stops working, that's the reason why...
Title: Re: That nearly worked Post by: stuwilson128 on 15 July, 2009, 04:22:44 PM I can feel withdrawal symptoms coming on already :o
