Model Technical and Interest => Flavia => Topic started by: Lindsay on 12 October, 2008, 02:13:48 PM
Title: How to unlock the fuel filler cap when you don't have the right key.....
Post by: Lindsay on 12 October, 2008, 02:13:48 PM
Went to drain the fuel tank this afternoon and actually had the foresight to try getting the fuel cap open first. Turns out, I don't have a key for it..........
Any suggestions as to the best way to get it open - tinopeners and brute force not being the number one preferred option.
Title: Re: How to unlock the fuel filler cap when you don't have the right key.....
Post by: fay66 on 12 October, 2008, 04:23:21 PM
Hi Lindsay,
I'm not that up on 2000's but it's worth checking if the fuel filler neck can be undone at the tank as it can be on Fulvia, if it is, then that way at least you should be able to drain the tank & work on the cap & filler pipe on the workbench.
Post by: Lindsay on 12 October, 2008, 04:26:15 PM
Hi Brian. Thanks for that. Just twigged the reason I don't have a key for the lock is that the 2 I do have are both for ignition - hence no key to do the doors either. Not exactly handy!
