Model Technical and Interest => Fulvia => Topic started by: Keithver on 20 November, 2023, 01:34:14 PM
Title: Slipping out of 2nd gear
Post by: Keithver on 20 November, 2023, 01:34:14 PM
Does anyone know if there are adjustments to the 5 speed gearbox.
When I approach a stop street in 2nd and take my foot off the accelerator, it slips out of 2nd. If I hold the lever in position it stays in 2nd without any force. Under acceleration she remains in gear. All other gears are fine.
Have I got an incorrect forward spring TAV 29 18 (below). My spring looks to be the same size.
The photo below shows a smaller spring that Pieces say is for the gearbox. Where does this go please
All suggestions would be appreciated
Title: Re: Slipping out of 2nd gear
Post by: lancialulu on 20 November, 2023, 03:07:07 PM
That smaller spring is correct. Indeed any similar spring will work but this is unlikely to cure slipping out of second.
On the dipstick side of the gearbox is a small lateral housing which contains a ball and spring (see Tav 33) you may find a stronger spring will help solve the problem but more correctly it is likely the 2nd gear is worn.
Post by: Keithver on 23 November, 2023, 10:05:07 AM
Thanks Tim. I will replace the spring with the smaller one and check the lateral housing on the weekend. I hope that will sort it out. Other wise It'll have to wait until I remove the box one day
Post by: lancialulu on 23 November, 2023, 10:14:06 AM
the plug in the lateral housing sometimes gets corroded in. At the end is an m3 thread where you can put a bolt to pull the plug out....
Post by: Keithver on 23 November, 2023, 11:33:20 AM
all the tricks of the trade. :) Thanks for the tip
Post by: lancialulu on 23 November, 2023, 12:28:54 PM
Not trade....
