Title: Radiator Fan Water Pump Bearing Post by: colinw on 13 April, 2021, 02:16:45 PM The bearings on my 1966 Flavia PF Coupe 1800 rad fan/ water pump (the assembly fitted with the thermostat and NOT oil filler) are noisy and need replacing. There are two as far as I can see in the parts book. Does anybody know where I can obtain them.
Thank you for your help. Regards Colin Title: Re: Radiator Fan Water Pump Bearing Post by: Mikenoangelo on 13 April, 2021, 03:23:27 PM If you know the size and spec or the bearing number, Simply Bearings are a good source.
https://simplybearings.co.uk/shop/Bearings/c3/index.html 01942 269 837 I've always found them helpful and reasonable in price. Vintage Bearings are also excellent and may even know which bearings are needed. https://www.vintagebearings.co.uk/ball-and-roller-bearings 01283 509 562 Mike Title: Re: Radiator Fan Water Pump Bearing Post by: colinw on 13 April, 2021, 09:07:30 PM Many thanks Mike for the quick response and info.I shall follow up with a call to vintage brgs.
Ideally I was looking to know the bearing numbers before I take the unit apart so I am not without the car for longer than necessary, so if anyone can help with this info I would be most grateful. Thank you. |
