Buy, Sell and Search => Spares required => Topic started by: CesareFerrari on 10 November, 2020, 06:34:19 PM
Title: Aiuto! Aprilia starting handle needed
Post by: CesareFerrari on 10 November, 2020, 06:34:19 PM
I need a starting handle for my Aprilia, and the need is an immediate one! Does any member have such an implement that he or she is willing to part with for a suitable consideration? I have had a disagreement with my starter motor and very much want to be mobile again. Saluti. Cesare
Title: Re: Aiuto! Aprilia starting handle needed
Post by: Mikenoangelo on 10 November, 2020, 08:55:04 PM
I had one made for the Augusta which is literally a simple crank which just needs two bends in a length of steel bar with a cross pin to engage the crankshaft dog. The bends are tight right angles so heat is needed - in normal times any metalworking shop would knock one up in no time if you can work out the dimensions or borrow one to copy. I didn't bother with a sleeve on the handle end, reckoning that I shall probably only use it when timing the engine and not need to worry about friction on my fingers.
Mike
Post by: tzf60 on 13 November, 2020, 10:51:15 AM
Cesare,
I have uploaded a drawing of a starter handle - see Aprilia section. It may help you get mobile again.
Tim F
