Model Technical and Interest => Fulvia => Topic started by: PABA on 29 March, 2020, 03:43:38 PM
Title: fulvia gearbox mount
Post by: PABA on 29 March, 2020, 03:43:38 PM
I’m trying to replace my fulvia s2  gearbox mount as they are past there best. I don’t seem to be able to open up the gap to remove the upper mount has anyone got any tips to help please.
Thanks in anticipation.
Paul
Title: Re: fulvia gearbox mount
Post by: lancialulu on 29 March, 2020, 05:40:21 PM
If you can, take the 4 bolts the top mount silent block and deal with it on the bench... soak heat etc.
you might need to move the coil and clutch cable out of the way, and possibly loosen the top 2 bell housing bolts so the mounting gets loose.
Post by: PABA on 30 March, 2020, 10:40:53 AM
Hello,
thanks for your replay, it's the two mounts on the side of the gearbox I'm trying to replace. Should I still remove the silent block, I did wonder if that's what is stopping the movement I need to get the new mount in?
Paul
Post by: lancialulu on 30 March, 2020, 04:16:24 PM
It's sandwiched. You can take the top bracket off the gearbox. I assume you have undone the big bolt and the sub sub frame? Dont undo the centre mounting  and support the mid point of the gearbox.
Post by: PABA on 01 April, 2020, 09:58:59 AM
Thanks I’ll give it a go.
