Model Technical and Interest => Flavia => Topic started by: BlueKSO on 01 March, 2019, 09:56:01 PM
Title: Sticky oil pressure relief valve
Post by: BlueKSO on 01 March, 2019, 09:56:01 PM
re;  63 Series 1 Flavia Coupe
Has anyone had any experience freeing off a sticky oil pressure relief valve.  Situated, as far I can make out from various diagrams, in the top of the oil filter canister, the part you take off when changing the filter.
All advice gratefully appreciated .
Cheers,  Peter
Title: Re: Sticky oil pressure relief valve
Post by: Richard Fridd on 02 March, 2019, 07:33:18 AM
Is it stuck open or shut? Is there a timing chain oil spout similar to a Fulvia, which can break off, causing low oil pressure?
Post by: BlueKSO on 02 March, 2019, 05:45:40 PM
No, the needle on the gauge, 90% of the time acts normally.  But every now and then goes way past max which it maintains for a short while and then suddenly jumps back to normal max.  Every indication that the relief valve is sticking open.  Iím just worried about my poor old oil cooler pipes and radiator!
Cheers, Peter
Post by: lancialulu on 02 March, 2019, 06:50:58 PM
Cheers, Peter
if. It does this when engine is hot then I doubt it is the relief valve as the oil pressure is then determined by cumulative tolerances in Lancia engines. If in doubt put another mechanical pressure gauge in series with the oil pressure pipe.
Post by: Richard Fridd on 03 March, 2019, 08:50:03 AM
Perhaps the sender is faulty?
Post by: BlueKSO on 03 March, 2019, 09:31:10 AM
Tim,  it can do it from cold.  Purely from past experience, not with Lancia mind you, Iíve found this kind of indicative behaviour points to the relief valve.  So if as I believe the valve is in the filter head, I just want to make sure Iím not going to upset any adjustments in my attempt to rectify it.
Richard,  as far as Iím aware the system is purely mechanical, no electrical sender unit is involved.
Cheers,  Peter
