Model Technical and Interest => Artena and Astura => Topic started by: Running Board on 19 October, 2022, 03:27:57 PM
Title: Brake servo
Post by: Running Board on 19 October, 2022, 03:27:57 PM
Does anyone have any information on setting up a Dewandre brake servo on an S3 astura , i seem to be getting all or nothing where all the pedal stays stuck to the floor until engine is turned off and vacuum goes and  pedal releases  , only way i can stop this is by leaving the bolt that connects it too the brake pedal loose , this is neither correct or ideal ,this has all happened after adjusting brake shoes up and getting the pedal travel reduced , the cross shaft adjustment was nearly maxed out so it was time to adjust the shoes, pedal position shifted so servo now needs to be adjusted too suit  any information greatly appreciated
