21 May, 2024, 03:02:00 PM *
Pages: 1 ... 13 14 15 16 17 [18]   Go Down
Author Topic: E55 LBR the parallel project  (Read 84260 times)
lancianut666
Slow but rough
« Reply #255 on: 19 May, 2024, 02:02:30 PM »
Finally found that receipt and swapped the plugs for the correct ones put them in and the little monkey started with out even having to charge the battery...the petrol is months old so the theory about the plugs might be true.
As the Y10 has been neglected a bit lately I treated it to a set of chrome locking wheel bolts.
Clarkey
« Reply #256 on: Today at 11:09:16 AM »
on the subject of not keeping fuel in your classic this may be ok if it is sufficiently  modern to have a plastic tank, but it is asking for trouble if it is a steel  tank. Steel rusts (just peer into any steel tank) in contact with moisture laden air (typical conditions for storage from autumn to spring), this leading to rust  getting into the fuel system blocking jets etc and rotting out the top of fuel tanks. I have always put my cars away with a full tank (near as dammit) when I am not using it. Never had any running problems 6 months later.
Tim,
I've always used E5 in 'Fay' without any additive since we were first forced to use it.
I now use the latest E5 98/99 octane and I'll never use E10.
The pre E10 E5 was never a problem , but we're now told petrol goes 'off"  and won't keep, but does this also apply to E5 now? as I usually keep the tank full over winter as well.
Pages: 1 ... 13 14 15 16 17 [18]   Go Up
Page created in 0.109 seconds with 21 queries.
