Model Technical and Interest => Flavia => Topic started by: Caracad on 18 August, 2022, 06:44:31 PM
Title: Water pump housing anyone?
Post by: Caracad on 18 August, 2022, 06:44:31 PM
Spigots on mine are badly corroded.
Title: Re: Water pump housing anyone?
Post by: bobhenry999 on 19 August, 2022, 02:38:38 PM
I got a good used one from Omicron a couple of years ago from my Coupe so it might be worth giving Andrew or Tristan a call.
Bob
Post by: BlueKSO on 26 August, 2022, 01:28:42 PM
What model number Flavia. The earlier 815 is different from the 819.
I know the whereabouts of a housing from an 819, because I had the water pump for my 815 !
Cheers,  Peter
Post by: lancialulu on 26 August, 2022, 04:36:57 PM
Cheers,  Peter
Sorry Peter but the 819 housing went to Australia!!!
Post by: Running Board on 27 August, 2022, 07:27:01 AM
I might have one , will have a look over the weekend
Post by: Caracad on 29 August, 2022, 07:47:53 AM
Thanks for the replies everyone.
My car is a Kugelfischer 2000 coupe. Pump is the same as the earlier 1500/1800 Kugelfischer cars.
I have managed to repair my pump housing. Found that 22mm copper pipe fitted nice and tightly into one spigot. I used epoxy adhesive to fix and seal it. The other spigot was okay with a clean up and repair with same adhesive.
I then found that the thermostat housing was even worse.
Have also made a temporary repair so that I can use the car while the weather is good.
Longer term I want to replace both housings when I can find replacements.
