21 May, 2024, 10:32:30 PM *
Author Topic: Trico vacuum operated washer bottle vacuum pump  (Read 1651 times)
FERGTS246
« on: 20 August, 2023, 01:36:28 PM »
Hi, Has anyone got a working, spare trico vacuum operated washer bottle vacuum pump that they would consider selling?
Its for a 1961 Flaminia
Thanks Chris
« Reply #1 on: 20 August, 2023, 03:35:42 PM »
I have one on my shelves in Italy. Back there on Wednesday so I will send you a photo then.
Mitka
« Reply #2 on: 20 August, 2023, 06:44:55 PM »
I got one, but needs rebuilding….
Sliding Pillar
« Reply #3 on: 21 August, 2023, 05:01:35 AM »
Is this the correct one?
https://www.holden.co.uk/p/trico_vacuum_operated_washer_bottle_later_type
They also supply this type
https://www.holden.co.uk/p/trico_vacuum_operated_washer_bottle_early_type
1955 Aurelia
1961 Lamborghini
« Reply #4 on: 21 August, 2023, 04:04:29 PM »
It may be more like this from a '62 Berlina, though I have a feeling some other models had a round bottle rather than one with one flat side.
« Reply #5 on: 21 August, 2023, 04:48:38 PM »
Is that vacuum operated Frank??
FERGTS246
« Reply #6 on: 22 August, 2023, 07:55:07 AM »
Thanks for all your comments. I don't need the whole unit (glass jar, lid, vacuum chamber), its just the brass vacuum chamber - or whatever its called.
See diagram attached.
Anyone know if it's possible to open up the vacuum chamber (reservoir) without damaging it, to renew the diaphragm?
« Reply #7 on: 22 August, 2023, 09:17:47 AM »
Yes Tim, it is vacuum operated though seems more complicated than the new replacements, perhaps because it links into more systems. The screen wash button also activates a vacuum servo that automatically switches on the wipers.
FERGTS246
« Reply #8 on: 22 August, 2023, 09:27:37 AM »
In case anyone's interested, I've found instructions online on how to service the Trico vacuum pump (servo?) that's fitted to Touring Flaminias:
www.bobine.nl/jaguar/13-electrical/trico-washer-pump-malfunctioning-and-repair
« Reply #9 on: 22 August, 2023, 02:24:32 PM »
I have done this my on B12 Trico which is the same. B12 sucker pump is still working.....
FERGTS246
« Reply #10 on: 23 August, 2023, 09:13:14 AM »
Tim, Any tips on making it a smooth exercise beyond what's on the online instructions?
« Reply #11 on: 23 August, 2023, 01:06:24 PM »
I am sure I wrote it up in May 2019 VL with home made diaphragm (which did not last so had to do it all again with the correct rubber ).
« Reply #12 on: 24 August, 2023, 08:36:32 AM »
Interestingly the Berlina seems to have been fitted with the Trico "co-ordinated washer system" as fitted to 1956-58 Cadillacs. There is a good write up on it here though Lancia have it fitted to the metal lidded glass bottle rather than a square plastic tank. http://www.forwardlook.net/forums/forums/thread-view.asp?tid=20011
Page created in 0.074 seconds with 20 queries.
