Model Technical and Interest => Fulvia => Topic started by: OldSparky on 29 September, 2023, 07:46:04 PM
Title: Absence of Timing marks on S1
Post by: OldSparky on 29 September, 2023, 07:46:04 PM
An earlier post ( in 2008)  referenced no timing marks on a S1 Fulvia.  I seem to have the same problem. Although TDC is possible any thoughts on setting timing ( ideally with strobe) Do I have to count teeth ( not sure on how many all the way round) and then calculate where to paint dot on and even this will have an error.
Clues welcome.
And  I thought ownership would be straightforward!
Title: Re: Absence of Timing marks on S1
Post by: Charles Frodsham on 29 September, 2023, 08:06:33 PM
There should be a TDC mark, but not an Ignition mark……is that what you have? If so you can time from TDC….10 degrees.
Post by: davidwheeler on 30 September, 2023, 01:30:30 PM
Agree, most strobes have a facility for setting the timing of the spark relative to tdc.
Post by: nistri on 02 October, 2023, 07:09:41 AM
On S1 1.3 engine timing is set 2 teeth before TDC which is indicated by a flywheel mark (often difficult to see because of old dirt).
